CDL Switch Options (93-94)
Sedro Woolley, WA
Been debating doing the CDL switch mod and pin 7 mod.
I know that you can use a 91-92 CDL switch and that an early 90's Tercel Hazard switch can be modified to work.... have also read that the truck hazard switch works, but some have said they don't light up.
I'm wondering what other options there might be?
Something I've considered - is that the FZJ80 uses a double din stereo - and that I would like bluetooth connectivity.... going with a standard 1 din stereo would leave 1/2 the opening available - and I also have an AE95 (88-92 Toyota Corolla Wagon Alltrac, with center locking diff). The diff setup in that vehicle is quite different - it uses a couple of VSV's to move vacuum to two different chambers, moving the lock mechanically. In my AE95 (~320k miles) both VSV's are shot and the CDL switch does nothing. The VSV's are a little different - one is open and the other closed with power, and they oppose when turned off... all other VSV's I've found just open when turned on.... so I've considered swapping that system to a couple of relays and normal VSV's, rendering the switch unnecessary.
In any event.... I'm wondering/curious if anyone has attempted to use an AE95 CDL switch:
(This isn't mine, just a google search popped this one up. Mine is slightly different, I think):
I think you're overthinking this- buy, install in 5 minutes, enjoy. Used switches are $50. no need to complicate things...
In my 93, I used a ECT button. I bought one used. The button does light up. It was cheaper than buying a CDL from a 91-92. Fits perfectly into one of the spare rounded button spots. I plan on re-labeling it when I get a chance (low priority).
What I'm getting at - something needs to be done to change how my AE95 actually locks (since it doesn't now, both VSV's are shot, and I have spares, but they work in a different manner) - so there's a good chance I will just bypass the entire stock CDL switch in it, leaving me with a 1 din sized factory CDL switch.
Was wondering if anyone has used one in the past or not.
Pretty much any Toyota hazard switch from the late 80s to 90s will work. I always try to grab a couple when I am at the pick n pull.
The problem I have - is the closest pick n pull is over an hour each way, and as of late their prices have pretty much quadrupled.... some items are probably cheaper new than from them.
Just go to a regular auto wrecker / recycler then. They will charge you a little to pull it, but it is still cheap. If it looks like the hazard switch in your 80, then it will work. The problem with some of these parts pickers is when you tell them you don't care what year or model of car it comes off of, it makes their head explode.
For anyone who cares - without any modification, the AE95 CDL switch does not work. There are 2 extra pins - the plug does fit (with the 2 extra not connected) but the wiring configuration must be different. I was thinking the 2 extra pins were the AE95 light for the CDL, which as you can see above is built into the switch/unit.
I could go as far as to rewire it, but I don't see a need. If it had worked, I would have gone that path but it didn't.
