CDL switch connector location?
tejas
anyone know where i go fishing for the CDL connector in the harness? i’m not finding it.
It’s there. It is in your bottom pic - the taped white connector. It has the foam around it. There is a protective connector you have to remove from the loom. It just clips in like a normal connection.
In the bottom pic... behind the yellow tape...
Look for that^^^
btw. fwiw here is how you get the security switch out. don’t go hunting for the two 2 wire connectors (actually not even sure if they come apart). but disconnect at the switch by rotating one and pulling out the other.
The piece with the yellow wires is the protective piece. You don’t need that. Your plug connects direct to the switch. Yep, everything else is all set plug and play.
The jumper in the connector is there b/c the center diff lock still uses the circuit when 4lo is selected in factory configuration...
My security switch is in same location and it unplugged from the two connections.
thanks man. i ended up having to pull it at the plug itself which was easy enough once i figured it out. not sure why those connectors were not coming off but they were close to the dash and hard to get at.
fwiw, that portion of the harness was a real mother to get over to the DS kickpanel.
there is a zip tie to the left of the stereo, one up under the harness that you have to pull from under the steering column and at least one up above the DS kickpanel. and probably one or two more at least.
Holy cow! Not easy for sure.
thanks a lot for the help.
so it is buttoned back up and the switch is just stuffed behind the kick panel.
i’m thinking of just buying some fobs and leaving it in.
do you happen to know if i can get it in one of these blanks on the left side of the steering column?
and does that thing just blink to show when it is armed by a fob?
It blinks when armed and it displays a series of blinks when programming the system. The other little mic is a glass break sensor. The manual is available online, and replacement fobs, both OEM and aftermarket are available as well.
