CDL, Partially Engaging.
Diesel Emissions Program Area, Colorado.
Hey all, long story short, drove across the states, started noticing an increasing vibration, typically worse with engine/drive line load. Started with the typical diagnostic steps, greased all the u-joints on my newish tom woods shafts. Seem to help a bit but was definitely still present.
So I figured why not drop the front shaft, and engage the CDL to rule out if thats a culprit.
4-high, engaged my difflock and I can hear and feel what I assume is the locking collar failing to engage all the way.
Sounds like its slipping on the splines, the CDL light is also flashing on and off rapidly when I shift into a drive or reverse gear.
So I lifted the the rear axle, so theres less load, same thing less noisy.
I feel like the first thing to do is to pull the actuator and lock the center diff by hand. But I wanted to get some of your thoughts.
Ill upload some videos later when I have more tkme to look at it again
Thanks.
Also, when I do push in the CDL button, I hear the actuator like normal, I did notice a while back on a trip, the light was flashing with the rig in 4low as well. Almost sporadic, not exactly a rhythmic flash to indicate a problem, but just randomly in frequency.
Well, just to update. I fixed the CDL actuator. Seemed like it bound up, and not able to get the collar to fully engage.
I took off the actuator, cycled it off the transfer case, from locked, to unlocked then to locked again.
I then forced the locking collar/shift fork into the locked position by hand.
Reinstalled actuator, cycled it a few times. Seems like its now forcing the collar into a fully locked position.
