CDL locked, pin-7 mod, CDL switch
Chattahoochee, FL
I have a 96 Landcruiser that I can't get the CDL to unlock on. I've driven forward and backward in hi and low range, done enough s-curves to make a ferret dizzy, and beat on it with various tools and implements of destruction...it's still locked.
I'm planning to do the CDL switch and pin-7 mod once I get a tuit that is round, but wondering if the pin-7 mod might fix it now? What are the chances that it's receiving a locked signal? Basically, will that disable the CDL at least until I add the CDL switch? This is assuming that the problem is electrical and not mechanical in nature...if it's truly stuck, then I guess I need to figure out how to get inside and unfreeze or replace it.
Thoughts?
The easiest way to determine if the CDL will unlock normally is to pull the low position connector off the transfer case. Much easier than the pin 7 mod. The connector is located at the rear of the transfer. Looking towards the front that connector is located at the 1 o'clock position.
Is the jumper/plug installed in the connector for the CDL switch?
Without the CDL switch, the jumper must be present.
If the jumper isn there, the CDL will lock, but not unlock.
Take the hazzard switch and plug it into the cdl plug to test. pin7 mod not required
Will pull the plug once this rain stops, assuming we don't get a lot of slush out of it which they've been threatening. Will take a look at the jumper but don't expect any problems there since it was working just fine right up to the moment that I took it out of low range and it stopped working.
Would a hazard switch make a good low budget substitute for a store-bought CDL switch? Is it just two wires in there being switched or? Do I really need to spend $60-90 on a switch or can I hack it?
On the pin-7 mod, the instructions I read said to use a special tool to take the pin out... Is that necessary or can I simply clip the wire?
Seems like that would also have the advantage of making it easier to reconnect if you changed your mind or made a mistake
My "special tool" is a 1mm jeweler's screwdriver. Pretty easy job, but yeah, you can just cut it if you want.
Hazzard switch works just as well as the CDL switch and is 1/5th the price. You may need to trim the plug slightly to get it to work, my 92 didn't my 96 did. It's obvious what needs to be done when you try to plug it in.
Yes, you can use a Hazard switch to try it. You MUST trim a "block rib" off the back of the plug in order to allow it to plug into the hazard switch. That's what I did on mine.
On the Pin-7 mod, I chose to unpin and fold the wire back and tape it off in order to make it so I could reinstall at a later date if I chose. Yes, you CAN clip the wire, but it is in a very tight place to install a butt splice later.
Are my dash lights receiving their signal from the same circuit that tells the CDL to lock and unlock or is it getting it from a physical sensor that actually knows if it is locked or unlocked? In other words, are the lights a reliable source of information on whether it is physically unlocked or not, or do they just know what it is supposed to be?
Getting that little pin out of the connector for the 7 pin mod is really tough, or was for me. I was afraid I was going to break the connector open, so I just cut and insulated the wire. After 20 minutes of muttering and cursing.
Now to wait for daylight and hopefully better weather :) Would be awesome if this fixed it, perhaps I can just hook the flashers up to some other unused switch...or go without them for the time being
Thoughts?
Idonot understand if it dosent unlock in H you have a problem ( in L it is sould be locked)
way do you think that pin 7 mod will help???
As I understand, the mod turns off the automatic locking in low so that you can switch it on and off manually with the CDL switch. If it's an electronics issue in the ECU or the like, unplugging the transfer case at the rear will accomplish the same thing but will not allow you to lock it with the CDL switch, this makes unplugging the transfer case only useful for troubleshooting or a short-term fix.
If the problem doesn't go away (if the center differential doesn't unlock) when you unplug it or disconnect the 7-pin wire, then the problem is mechanical inside the transfer case
Other than the dash indicator how have you determined that the CDL is actually locked? If relying on the dash indicator only then the indicator circuit could be malfunctioning without the CDL being locked.
It fights me going around curves, has a hard time moving slow with wheels turned (I had to physically check to make sure the parking brake wasn't on), and if I turn too tight I hear noise coming from the CVs
Adding the switch id unlikely to solve the problem, best to figure what is wrong and repair it. When the actuator is switched, does the actuator motor run, does the relay click?
Some posts that explain how it works: CDL Actuator Fun
I'm not adding the switch, I want to see if killing the signal unlocks it... Adding a switch would come later
Unplugging the L4 position switch would do that. When the transfer is shifted, does the actuator motor run, does the relay click?
