cdl help
I had a new motor put in my locked 97 cruiser and the mechanic left the main wiring harness against the firewall laying on the back of the motor. Needless to say the wires had been shorting out for some time until I located the problem. One of the things shorting was the cdl. There was a clicking under dash and abs and cdl lights flashing. After fixing the shorting problem I couldn't lock the front and rear lockers. I jumpered the front switch on the transfer case and the light come on and I can lock both from and rear lockers. I also replaced that switch but no lights. I replaced the rear (4L) switch and still nothing although I could hear the click under the dash but still nothing at the transfer case. I guess the only thing that is not working is the transfer case locking up. I don't know where to check next any help would be greatly appreciated. Also, since it doesn't appear that the cdl is locked, just lights on, I would assume it won't hurt anything driving it with the jumper hooked up?
Here is a good thread on CDL problems: https://forum.ih8mud.com/threads/cdl-actuator-fun.68015/
Have someone lay under the truck while you try to engage the cdl. If they hear an electric motor running sound, that probably means that a bushing is seized in the actuator. If they do not hear an electric motor sound then that probably means that either the motor is bound up or is not getting voltage.
If you don't hear the motor you should check for voltage going to the motor. IIRC you can trace the two wires that go to the motor back to a disconnect and check the pins at the disconnect. If there isn't voltage, you have a wiring problem. If there is voltage, you have a motor problem. Most of the time, if you have a motor problem, you can fix it by taking the motor out, clean it, grease it, and glue any detached magnets back into place.
Only have CDL on our truck. However, if there was any chance your mechanic was under the dash, probably worth checking to see that the CDL switch is still plugged into the harness if installed. Not from the factory, but many here have it and if there is a switch on the dash, then someone has pulled the plug that is attached to the harness. If the dash switch is then not hooked into the harness, it may be a problem.
I can't remember if the dummy plug on the CDL harness had a jumper in it or if it was merely protective. Anyone know?
Your CDL is not locking, but determining whether it's because of the actuator on the transfer case or the control box in the driver side kick panel will require further investigation. Read the thread linked to in Eradicator's post #2. It's excellent. The fuse for the CDL and fr/rr lockers is 30A and things like the windings in the actuator motor or etches on the controller board can burn up before the fuse blows. Are you sure you repaired all the problems with the burnt wiring harness? I wouldn't drive around with the locker fuse in place until you figure out your problem. As discussed in the other thread, if the CDL locker is frozen half way locked or unlocked, then power is applied to the actuator motor whenever the ignition switch is in the ON position and the windings on the motor will eventually fry. And that motor is not serviced separately from the center diff.
I would imagine it is fried. The relay had buzzing for sometime before I found out the problem. What will I be losing in 4 wheel drive or either damaging by driving it with the cdl sensor jumpered which allows me to lock the front and rear lockers in hi or lo? Locked front and rear just no center lock.
If you pull the fuse in order to protect the actuator and wiring from further damage you will not be able to lock the front and rear, because they use the same fuse as the CDL. As a trail fix you can jump the CDL sensor in order to trick it into allowing you to lock the front and rear. Have you checked for voltage going to the motor yet?
I have not checked voltage yet. I have jumped the cdl sensor and have locked my cdl. I am wondering how much capability am I losing by running the rig like this? Locked front and rear but no center. And will I hurt anything by doing that?
We ran like that when our CDL actuator went out on the trail for a few days. While still very capable, it was a very noticeable difference without it locked. We had to use a lot more momentum and there was a lot of tire spinning that wouldn't have been happening with CDL.
Good enough, I will try looking into it when I get a chance. Thanks for the reply.
I forgot to mention that our actuator motor was running, just not locking up. If your motor runs then there is no chance of damaging anything. If your motor does not run, it could be stuck in between locked and unlocked trying to turn. If it is doing that, then there is a chance of damaging something, since the motor will be constantly drawing more amps than the circuit can handle. That is what happened to Tools R Us in the thread that I linked to above.
