CDL help
MoGas
Central Scrutinizer
GOLD Star
Gold Canyon, AZ
I searched and came up empty, I checked FAQ, still no answer.......
I am looking for the writeup that someone did that was great about removing, rebuilding and re installing the CDL motor.
Thanx,
Dave
Pretty please??
I think Tools has some experience with that. Either search his name, or ask him direct.
-Spike
center differential locker
I removed mine on my 91. Tried to rebuild it but the windings on the motor were shot. Wound up replacing with a new one for buco dinero.
Not too complicated. It's a simple actuator motor with finger contacts. On mine I had to lower the tranny cross member about 6" with a floor jack to get to the top of the transfer. This gave me enough room to work. Have someone watching hoses and bits under the bonnet as you lower to avoid damage.
When re-installing, be sure the motor position matches the internal gear position in the transfer case. In other words locked or unlocked. You can use the small gear on the motor housing to manually lock/unlock the center diff. You will know when it is locked or unlocked simply by moving a drivshaft by hand. When the other one moves it's locked.
Use the orange Toyota FIPG when putting bits back on.
