CDL dash light
Hi guys,
I connected the CDL switch and I think it works. The problem is that the instrument panel CDL light does not come on or the ABS light. I checked the bulbs and they work fine.
Any advice?
1994 Land cruiser
Didthe lights work when you put it in 4 Lo before you installed the switch?
No it did not work before. I also don't think the CDL came on when I put it to 4L.
But with the new switch I can hear it work when I switch it on.
I had the same issue and changing the cdl sensor/switch fixed it right up. After doing some research I found that the sensor switch is very common and has many different uses. After cross referencing some #s I ended up at Auto Zone down the street. they have one made by Duralast labeled as a backup lamp sensor , $22 bucks out the door. AutoZone Part # JA449. Perfect match, works great. Another reference is #201-1788 by Beck Arnley. Same switch, different maker. You can find it all over ebay and Amazon. From what I understand the OEM Toyota switch is pricey. StucknKS great ref, thanks!
Ha, that's nice to know. I replaced mine a looong time ago with OEM and it hurt.
