ccot brake kit
I just received half of my order from ccot. 5 brake cylinders 4 shoes, no parking brake assembly. Anyway i got started on the rear brakes. The passenger rear actually. I have the manual and am pretty sure i have the correct setup happening. regardless the the lead end of the shoe is to wide to fit into the cylinder slot. has anyone experienced this. 1970 fj55
I ordered the full kit so the parts should jive.
Unless I'm missing something...
If the slot's too narrow, you've got the shoe on backwards. If you look at the shoe, it's got a fat edge and a narrow one. I assume you know this based on what you've written, so what makes you think that you've got the correct "lead end" as opposed to the other way around? Sometimes there is a substantial difference in the location of the shoe's friction material, so don't base the orientation solely on that.
HTH,
Eric
There is one wide end and one narrow end on the shoe. Turn the shoe around. It should work. I ordered the same kit (without the wheel cylinders) several months ago. There weren't all the correct parts in the kit, so I called them. They bent over backwards to make it right. They may not have the highest quality stuff, but I have found they have excellent customer service. That's a bonus in my book.
Good luck!
:cheers:
If a manual referrs to the right hand rear brake, isn't that the right hand as if you were sitting in the vehicle facing forward? Does the fat in go into the adjustable side of the cylinder. That is how the PO had it setup, but he also had both the return springs on the same side.
Yes, I think you're right about the right rear thing.
[had to run out to the garage and inspect the leftover parts pile :D ]
The fattened side of the shoe goes with the star adjuster.
I never had the little retainer pins, so I always just put both springs on the back side of the shoes to keep everything in place while I got the drum on. I never had any uneven wear or adverse effects from doing it that way. Honestly, wear was the least of my concerns.
Oh yeah - I:heart:myreardisks :D
One other thing - the adjustable slot for the shoe is not cut straight. It's slanted and is meant to fit the fat part of the shoe one way only. You'll see what I mean if you look at it closely.
I don't know how long I fought that one the first time I did it in the dark :doh:
So what are you guys thinking? The fat side doesn't fit in either side of the cylinder. Could the cylinders be wrong, i was under the impression that the shoe are pretty standard. It is kind of wierd that i only received 5 cylinders instead of 8. But then again i only got 4 shoes. One other question, My hard line to the "new master" doesnt fit. What a beautiful Saturday.
If the fat side of the shoe doesn't fit in either side of the cylinder, it's time to call CCOT. Oddly enough, I just looked at the junk front drums in the pile and it looks like the shoes will fit either way - the slots look to be wide on both ends of both cylinders :confused:
Got calipers? Take some measurements and post them up. Width of the piston slot, width of the adjuster slot, thickness of the narrow end of the shoe, thickness of the fat end of the shoe. I'll compare to my old parts for you.
[edit] It's funny how many people recognize my avatar. I went to see Talladega Nights a couple weeks ago (Gary Cole plays Ricky Bobby's dad) and someone in the theater yelled out "It's Lumberg!" and I just cracked up.
