CCD backup camera
Seattle Area
I was asked to post up some details on my backup camera. Here it is.
The backup camera is most useful for backing up to a trailer. It is also moderately useful for 4 wheel backing at night since it is fully IR. It is not terribly useful for parking lot backing since the camera is in the middle and won't tell you anything about the corners of the truck where the impact usually occurs.
On to some details.
I used this camera.
http://store.mp3car.com/CCD_Infrared_Camera_p/com-003.htm
The fact that it says it can be used as a backup camera means that the image is automatically switched right to left for you.
The block to mount the camera on my bumper was made by my dad on his Mill. It was carved out of some plastic I purchased at boeing surplus.
I used this LCD and mounted it in my dash.
http://store.mp3car.com/Mp3Car_TRANS_7_VGA_transflective_p/mon-010.htm
The expensive LCD was only worth it since I use the monitor for my whole car-computer setup. More info on the car-computer and the LCD mount can be found here.
http://www.mp3car.com/vbulletin/show-off-your-project/72552-mp3-project-land-cruiser-done.html
I don't have pics of the camera in use. I'll try and get some of those and post them tonight. For now, I included a pic of the LCD in the dash.
The LCD takes VGA inputs as well as composite. The camera puts out composite so one only needs to make the LCD switch sources to make use of the camera. There are various solutions to cause this to happen. My solution was to build a PIC (micro controller) that causes the LCD to switch sources when I go into reverse and then switch back when I come out of reverse.
Full details of the PIC controller can be found here:
http://www.mp3car.com/vbulletin/lcd-display/74434-pic-backup-camera-source-switcher-lilliput.html
The camera is powered on via a relay when the truck goes into reverse. For this I used the backup light to trigger the relay. The camera is mounted such that the trailer ball is visible in the bottom portion of the image. This makes it perfect for backing up to hitch up a trailer.
I hope this helps.
p.s. I feel it necessary to note that both the hitch and the mounting bolts for the camera block have been fully repainted since the picture was taken. Maybe I'll try and get some new ones tonight.
Nice. That's what I have in mind for mine with a variation for the camera. I want to be able hang the camera under the truck, (with adequate rock protection) to get a view of the front axle. What software do you use to interface the touch screen with the computer?
By that do you mean the actual touch screen portion and not the LCD? If so then the touch screen just acts like a mouse. Windows has the ability to use multiple mouses at once. In fact, I have 3 running. The touchscreen, a regular mouse, and a shuttle express which I use for browsing/selecting music. The touchscreen software came with it and it is just a mouse driver as far as windows is concerned.
Updated pics
Updated Pics:
If I remember, I'll get some pics in the dark of the camera using IR. Its as bright as day with the backup lights. It would likely be bright even w/o them since it has built in IR illuminators.
That is a very cool system,
What was the ballpark figure for final cost? (the whole kit and caboodle)
Prolly out of my range, but I could put pieces on my Christmas list....
Cost:
Well, the computer is not nessasary for the backup camera functionality. So just camera, low cost LCD, LCD mount could be around $500. Note that the camera I used in that price is about the best one can get. IR functionality, IR illuminators, Color, and good 60 degree (I think) view. I have seen cameras on ebay for $50 (verses this one for $170). I have no idea how good/bad the cheapys are.
I know I had about $1K into my initial computers system including base line LCD. I later upgraded to a better LCD due to daylight readability issues.
Same (approximate) position at night.
Eric,
Thanks for the write-up, I appreciate it! Now I'm going to have to do some reading on your whole car computer system. :grinpimp:
For now, my wife's doing ok at hand signals, but I know she'd go for a backup camera.... :D
I'll start piecing one together over the winter so it will be ready for next camping season. :cool:
:cheers:
