CC died today...
San Diego, CA
So I was driving on the highway today and used the CC ( I dont use it often). I then put on the brakes and it went off like its supposed to. Later on after the traffic I tried to reapply it and it would not turn on.. No green CC light at all, nothing. I did a quick mud search and the info I found on it was pretty complexly worded for me (I have no knowledge of cars.) I am thinking that this might be a blown fuse, but is there any other ideas?
:crybaby:
(it'll be something easy. start hunting)
Possible blown fuse. If the fuse is good and if you don't use that CC that much, why not just take it out of the truck and toss it away:D.
check the brake light switch, the same thing happened on my tacoma. the brake lights still worked, but the other half of the switch for the CC died
well heres and interesting thing, so i tried it again when i went out and it worked... my guess is i hit an incline at the hill and it decresed over 10mph on the highway causing it to disengage and maybe i mispressed the master button... Whatever it is for now its fixed.
If the cruise control cuts out, it won't re-engage until you've turned the engine off and back on.
Hmm so if it disengages because of the drop in 10mph or if I go under the 25mph limit it won't reinngage until I turn the carr on or off again?
The cruise control on these trucks is vacuum actuated. If you loose a vacuum line, they will cut out.
The '92 we had had a rotted vacuum line which resulted in spotty cruise control. Some days it would work, some it wouldn't.
When I blew my EGR vacuum modulator valve, it dropped the vacuum and the cruise control stopped working.
In both cases, re-establishing proper vacuum cured the faulty cruise control.
IMHO YMMV.
My CC doesn't work if I overuse it.
Wait, isn't this a tech forum? :D
-Spike
Well I am going to take a spin around the highway for a bit tommorrow morning to test the cruise control and if it is indeed spotty.
always good to know what year vehicle we're incorrectly diagnosing.....
DougM
My 95 recently blinked the Cruise light when I was using cruise when I was trying to re-engage it. Light blinked then went out. Tried power switch again, light blinked and went out. Then... pressed the switch again and nothing, no light or anything. Next time I drove the car, it worked.
I then mentioned it to my :princess:. (I try to bring up stuff that could cause $$$ leakage subtly). She mentioned that while she was driving on a recent road trip, it did not work at all for her... Thanks for mentioning that, honey... I honestly don't know if she does not know how to use it or if there was actually a problem, and don't know that I want to get into the fight to find out.
the cc on my 97 lx450 will come on and operate fine, but will not reset at low speeds around 45 to 50 mph. It will reset at highway speeds 55 to 70+ mph. can not seem to fine any info on this.
Well CC will not reset at low speeds because it is designed to not work at speeds under 45mph and will not come back on until you achieve a higher speed than that. Also, if you hit a hill when in cc and the cruiser drops 10mph+ in difference to the set speed, cc will shut off in the same fashion.
