Does anyone know if you can use a CB antenna also for a Radio antenna? If so has anyone done it to thier 80? I ask b/c i have a broken radio antenna and would like to replace it with a CB antenna (short one of like 2 feet) that i can also use for the CB.
I was thinking about this too... I don't see why you would need another antenna or a special combo antenna... FM receives on pretty much any old piece of metal (people stick coat hangers in when their antenna breaks off). I would think you could tie the antenna line into the pos/ground of the CB antenna... it should work. The only thing I would think of as a problem is that this could change the SWR of your CB since you are technically extending the antenna (by adding more wire). Since the FM is only receiving it shouldn't mess up the CB... has anyone tried this or is anyone scientifically inclined here? Could the FM get some noise when the CB is transmitting though?
My antenna isn't broken but my FM reception sucks and it looks stupid to have 2 antennas up front
Isn't an antenna like a combination CB/AM/FM unit sort of like an all-season tire? Kind of OK at everything but not really good at any thing?
In my experience, the most important part of a good CB radio is the antenna. You can have a cheap radio and make up for it with a good, well-placed antenna.
Years ago I used to have a combo antenna but it didn't do either the FM or the CB well at all.
I would be interested in this as well / using a Wilson CB antenna for the best possible CB signal / but would like to know how "bad" this will end up being on the FM side?
