I just got a 2 Meter Ham radio for Christmas. It was preowned and I'm glad it is because then I can try it and see if I actually use it without feeling guilty about another expense. Anyway, the pitiful little 1" speaker sounded like crap. So I decided to use an external speaker. I already have so much junk in my Cruiser I decided another speaker wasn't needed to add more clutter. So I decided to use the dash speakers which are no longer used as I have an aftermarket headunit for tunes. So I wired a 1/8" Mono plug to my front speakers. Here's the little bit of trivia that will help some folks better match impedence. Most CBs and HAM radios take a 8 Ohm speaker. The factory dash speakers are 4 Ohms. I cut the capicitors out on the dash speakers and then wired the positive of the plug (center) to the DS speaker. Then I ran the negative from the DS speaker over to the positive on the PS speaker and then the negative off the passenger side speaker back the plug (outer lead). This makes the total load to the CB/Ham amp at 8 Ohms making it happy. The factory speakers are only rated at 2 watts and my radio puts out 8 watts. But I'm not even at 1/4 volume and the cab is filled with sound. This is a lot better solution than adding another speaker and it helps to keep sound projecting forward if you install the CB or Ham in a position where the speakers won't be as audible.
