Catlytic Converter
How many miles on your rig? Why is it bad?
These cats don't fail very often, and usually when they do there is a cause for it (such as oil in the exhaust).
When I pulled my cats off at 150k miles they were in nearly perfect condition, only a very few of cells were blocked and I wouldn't hesitate to run them for another 100k+.
The OEM cats are VERY beefy and you can probably run just one if your state laws allow it. You can also go with an aftermarket cat, I would get an oversized one if you go that route. There's some cat's recommended for turbo applictions that seem to work good, I know a couple people who have the "standard" sized cats and will occassionally get O2 sensor CEL's.
I went to the shop to have a hanger put on. The exhaust pipe was hitting the frame on the rear of the truck. I guess the PO put on a aftermarket muffler and the hanger was not put back on. Whike the shop was putting on the hanger he noticed a rattle from the from around the cats and said that the front one was bad. He said the inside was broken.
An impact can destroy them, literally physically break them into pieces. If they are rattling, that's not a good sign.
Keep the cat as you can still sell it whether it's broken or not (the metal recyclers don't care, they destroy it anyway). You will at least recoup a little of your cost that way.
Do you have any brands you can recommend for cats? (name and model)
I don't. I'm not sure which cat that Baktasht put on my rig but it's way oversized (I really emphasized a larger cat as some people have had issues with smaller ones). It's about the same size as OEM, or slightly smaller.
You could PM him and find out the brand and model number. IIRC it wasn't super cheap (around the same price as that Magnaflow) and might even be the same one that's linked to. I'd feel comfortable recommending it as it's physically sized similar to OEM and I have had no codes running it (so far, knock on wood).
The one that's linked to above is pretty decent sized, so that one would likely work as well. I would do some research on the cats that folks are running, especially the turbo folks. If you run a cat that works for a blown 80, then it will work without a doubt for a NA 80.
