Cat delete options
Tri Cities, Washington
The exhaust system on my 91' is vintage from front to back and to be honest is craptastic in every way imaginable.
I live in an area that does not require any sort of smog checks. I would like to just replace the entire thing from the manifold back, delete the cats and excess pipes and just run a muffler inline somewhere.
thought is that it will not just be cleaner looking (hate the low hanging cat and heat shield on the drivers side) but also should breathe better.
Anyone do this? Any issues with check engine lights coming on? Anything i should know about before doing this?
Thanks!
I deleted both cats in my 91. I just welded in straight pipes. No codes or anything. Noticeable power increase and mileage increase.
just deleting cats and angling a y-pipe up to the frame over orig. exhaust piece nets you a bit of clearance:
first pic is of dual straight pipes in place of cats
second is of a y-pipe which angles up to a higher point on the stock frame-over bend
its hard to see in second pic- but you could easily run a straight plate under the exhaust /cat area and then up to a slider.........vs having to dip down under cats then up as in traditional slider setups. So you would basically have straight extension from the tranny/tcase crossmember at the frame height directly out and under the cat area vs hanging below frame height.
Running straight mufflers down the side are noisier and have a ton more "drone" to deal with. been there done that.
above is easiest option. best option is deleting rockers and routing around the body mount vs under it......then over frame and out back.....but a ton more work. This would put your exhaust a good 2-3" higher than abovve option basically level with body mount
