Cat Conv. removal
Louisville, KY
For a smogged 1980 FJ40, what would be the effects of taking out the cat. conv. and replacing with a cat by pass. Would it even be worth it in terms of power gain/flow?
Thanks.
Try a 20-30 hp increase for one. Cutting off the cat converter will not do much for your rig unless it is so detoriated inside that it blocks air flow. To truely get good airflow, you need to get rid of the exhaust heater flap inside the OEM exhaust header. This is a misguided 70's method of reheating the exhaust vapors to burn out unburned fuel (at the expense of increased fuel usage :confused: ). Man-a-fre has a replacement header for $150.00. This WILL increase your horsepower and add to your mileage, regardless of what the EPA will have you believe.
I cut them off of my 62. Didn't really notice a power increase but it does sound bad ass.
