Castor Correction - Landtank version
Reno, NV
Since lifting my truck with OME Heavies and using OME CC bushings, I have never been satisfied with the handling performance, especially on the highway with cross winds. I knew my castor must be on the low side and I would need to find another correction method. I wanted to post up my experience for another point of reference for others.
A trip to the alignment shop verified my concerns, my readings (with the OME CC bushings in) were -0.9* on each side (nice to find them even however), well under the specified range of 2.0*-4.0*
When considering correction, I wanted something that was within my mechanical abilities, this eliminated the washer method (I don't know how to weld). I considered Slee bushings (not enough correction)
MAF Drop brackets (http://www.man-a-fre.com/pa/4plus80seriesdropbrackets.htm) could interfere with future slider install
Slee Plates (http://www.sleeoffroad.com/products/suspension_pieces_spacers.htm) unpredictable effect on driveline issues
Landtank's Plates (https://forum.ih8mud.com/showthread.php?t=58518&highlight=castor)
After reading thread after thread about drive-line issues, and lots of questions exchanged with Landtank, I settled on his approach as it's the only one that would address both my castor issue and have a predictable result with the drive-line and I would be able to install these on my own and learn more about my truck in the process.
I knew we would be lining up the front pinion for a Double Cardan shaft and elected to have one made by a local shop. I used the shaft from a Pre-Runner and my own front shaft. My next step was to remove the OME bushings from the arms and replace with OEM and then get another castor reading. I dropped the arms, found a local shop to do the pressing for $20, reinstalled and headed back down to the same alignment shop. My castor readings now -3.2* each side:eek: and the truck drove like crap. I got the truck home, installed the DC shaft and took some measurements. After looking at the numbers, I believe we settled on 7.0* of correction (Rick, jump in and correct me if we went with more). Rick pre-drilled the plates, put together a drill kit and shipped it off to me.
I have to admit, I was a little intimidated at first, but knew if I took it slow and followed Rick's directions, it would be fine, and once I got going all worries went away. One thing thing that did trip me up was the right angle drill. Millwaukee makes several models with the same chuck size, so you need to make sure you don't rent "The Hawg"
and instead, rent one that looks like this. You can notice that the head behind the chuck is much thicker on The Hawg and the passenger side knuckle gets in the way.
The install went very smoothly. Rick included some very clear directions and I followed them closely, taking my time. He included a drill "kit" which included 2 sets of bits, 4 different sizes and two shaft lengths. Starting on the passenger side was a good idea for several reasons, I got the toughest drilling (around the pass knuckle) and the plates will only align one way do to the diff housing. Arm fatigue was the hardest part as you have the drill up there for a long time, slowly drilling each hole out bit by bit. I did find that turning the wheels once direction or the other made it a bit easier to get the drill in there and see what you are doing. After all the holes were drilled, it was a matter of bolting everything in place, installing the DC shaft and taking it out on a test run. In the end, I think the actual install of the plates was in the 6-7 hour range. I think it's a fair assessment for the average DIY guy. I took my time, but I did not waste my time either. I am VERY pleased with the results, the truck now handles like I want, no darting, tracks straight, the wheels want to return to center etc. I have not been back to the alignment shop yet for new numbers, but will update this post once I have.
The day after install, I loaded the Cruiser down with 100's of pounds of "crap" and we headed home to Missoula, MT for X-Mas (500 miles) and I could not have been more pleased with the handling. I did have a slight vibration which I later figured out was my overfilling of the slip yoke on the DC shaft. I pulled the zerk to relieve pressure and the vib is all but gone. I am still going to drop it, purge the syn I have in there and replace with dino.
I have to say, getting the castor straight AND no driveline issues are well worth the effort.
I'd be happy to field any questions and I'm sure Rick would be happy address anything as well.
Hope this helps other Cruiserheads in the future with their decision making process.:cheers:
Good additional reading;
DC Shaft https://forum.ih8mud.com/showthread.php?t=29715&highlight=double+cardan
Vibes https://forum.ih8mud.com/showthread.php?t=68938&highlight=castor
Thanks for the nice write up showing caster measurements with each setup. I'm anxious to see the final caster numbers.
Thanks. I should be able to get them later this week. It's night and day difference from where I was before. We got some really hard winds 60+mph coming through the Skagit valley recently and I would have been blown off the road with the old set-up, the new one tracked along just fine.
Just to clarify, this is the right angle drill to rent. Your local Home Depot should have them in the tool rental area.
attachment.php
-B-
Right Angle Drill Question
Is the Milwaukee drill the only one that has a head small enough to fit where you need to drill for this?
Are there clearance issues with the other (DeWalt) right angle drill designs?
No Idea, the only drill I had access to was the milwaukee and it's an easy rental at Home Depot for thse who don't have access to it. The Dewalt and others might work just as well.
I really only looked at Milwaukee drills, so I'm not sure if the other brands would work or not. If you take a look at where the front bolt on the axle near the pumpkin is, you'll get an idea of the size head you'll need. FWIW Milwaukee seemed to be abundant at rental shops in the area, key was getting the right one.
But you had no problem getting a straight shot at the bracket with the Milwaukee, right?
I can't seem to manuever the DeWalt in such a way that gives me a straight approach to the pilot hole. It's close, but not straight, which means I'll have even more issues trying to drill the second bracket through the first.
I *may* started out slightly angled, but once the bit started in a little, I was able to straighten it out, did not I found a little extra room by turn the all the way to the side. Assuming you got the "drill kit" as well as pre-drilled plates?
Yes, got the drill kit, too. I finagled it a little more and got to an acceptable angle to try . . . drilled for a bit with a little or no progress and now, after I look at the tip of the bit, it appears this first bit's tip is off-center. That would probably reduce the cutting effectiveness. I'm now heading out to find another drill bit. bummer! stuff happens.
Okay, I'm going to keep at it with this DeWalt and if it appears it won't work in the first two holes, I'll bag it and get the Milwaukee.
Get several. Those smaller sizes seem to get dull pretty quick, even with a LOT of cutting oil. The first holes were at a bit of an angle for me because of the drill positioning. I rented the same Milwaukee at Home Depot. After you get through the first side, you can shift positions and line up with the pre-drilled hole on the other side.
As Rick can attest, I found that lubricating with copious quantities of your favorite beer tends to slow things down a bit . ... pardon the pun. :D
I'm still waiting for caster sweep numbers from Peepers and Montana.
-B-
As more guys are installing these it looks like the 1/8" bits are going to be sacrificial. I basically get the 12" bits from your local Home Depot or Lowes and cut them down to 5" and 7" lengths.
Also adjusting the depth of the bit in the chuck might help you get the head of the drill in a better position.
Sorry about the bit problem.
-B-
I used lots of both oil and :beer: and had no problems, Rick did an excellent job in the directions.
Yeah, I'm a slacker, and still have not had another sweep done, soon though :D
It's good to hear what works and what doesn't, I've got access to a dewalt drill and am in line for the "install kit". Hope all goes smooth.;)
The first couple installs went smooth but they were done with new bits. I haven't announced these in the storefront yet for this reason. I want to work through this with some people to get the issues worked out.
Hey, everyone--back at it this morning and it is working much better.
I picked up two more Blu-Mol 12" 1/8" bits but have not used them so far. My buddy has a Drill Doctor and he resharpened the offcenter bit and it's working as it should now. No problems. Have the first two 1/8" holes drilled. Depending on how things go, I may not need the new bits. I'll let you know how it goes, Rick--thanks for the reply to the PM and the advice!
Have also been able to make the DeWalt drill work so far. Have had to stop a couple of times while drilling to adjust the bit position but no big deal really.
I am using oil and am making sure I never see smoke--with the sharpened bit, I was able to drill two holes in the same time I spent monkeying with one on Friday.
Well--back to work!:cheers:
No problem, Rick--like I said, stuff happens. By no means was I upset or anything about it. Just glad things are working out now. And I have been adjusting the depth of the bit in the chuck to help with the drill position. It gives me an excuse to set the drill down!
Thanks again for making these plates!
