Caster measuring- is this setup OK?
Norway
Website
www.inditravel.org
I am measuring caster this way with a standard caster measurer from Ebay. But because of the alloy free wheeling hub it is not possible to fix the measurer to center (by magnets) where it should go. So i used a flat iron on top of the hub. As we are measuring in a plane parallel with the wheel, this should be the same? Or am I wrong?
The turn plates are two garbage bags with grease between. The weight is used to measure angels, +/- 20 degrees.
Caster worked out to be minus 2 degrees which I assumed since it is not tracking well after 2" lift.
