Caster help needed
SoCal
I had the caster checked on the cruiser this morning, I'm lifted 850s in the front 860s in the rear with OME correction bushings, ARB front, but no winch. I'm positive 0.5 right and 0.6 left side. I'm thinking of going to slees plates with maybe a upgrade to 850Js so I can level out the truck. Anyone running this setup? I don't think I'm going to get the correction I need w/ bushings, even the blues. The plates say they are for a 4 inch lift, so I'm thinking they give 4 to 5 degrees of correction? I anyone has been where I am I could use some input. Also, do you get into driveshaft vibe issues w/ J's or just when you go to 4 inchers?
Thanks
Aaron
this is my truck
vibration issues has nothing to to with what springs you have. It has to do with what caster correction you use. From what you posted you need caster plates to properly correct for the caster you have now, adding Js will put you on the low side of the scale. I have no idea how much Slee's plates correct for but I'd assume you will need a DC shaft.
Rick I do not think you can rule out the springs completely. If people read that they will think that lift height has nothing to do with it, but it does. Caster and pinion angle is related, but if you lift the truck you also have to consider the transfercase end of the equation.
Wow, I think my post caught the eye of the right person, Mr. Slee, would you recommend your plates for my application? Also, in your experience, do they require a DC driveshaft?
Thanks for your input.
Aaron
I think I understand that, taller springs just rotate the axle down further on the arch generated by the arms. I mean if J springs are corrected for castor with the appropriate means does that usually put your driveshaft angle more than a stock driveshaft will like.
There is no one proper correction method for any one spring. When determining what to use for caster correction it is not centered around the springs. They are only part of the equation, the other part is how much weight you have on it.
A light truck with Js and a heavy truck with Slee's 4" springs usually require the same method of correction. That's because the trucks are close to being the same height.
So the height of the truck determines what is needed to correct for caster and the method used suggests the drive shaft needed to run smooth.
