Caster Correction Shims
Colorado
I've decided to add the caster shims on my 62 with long shackles but I don't really see how they work. If it's simply the angle brings it back I can accept it w/o understanding the concept. :doh:
Spectors pics (below) show thw install and theory which is okay but how do I do it with the shackles flip kit?
TIA!
what you are trying to do it's move back to the factory position ( level ) the front axle .. coz usually when you run a suspension lift ( lifted springs ) and longer shackles the front axle will rotate up ( the pinion rotate upwards pointing to the t-case )
This rotation will affect your caster settings ..
So the caster shims with used correctly will move the pinion down and bring you a caster correction ..
Hopefully your leafspring center pin will keep you from rotating the axle inside the ubolts. Just in case, the shim gets bolted into the pack with a center pin, not sandwiched in between the pack and the perch. I recommend using new center pins. They are butter bolts (very soft) and should not be used to bring the leaves together. Use clamps for that and snug the center pin (bolt.) If you don't have leaf spring center pins (bolts) post up and we will start from there.
:whoops:
I didn't realize the center pin went through the shim. It makes sense now. So I guess I need longer center pins along with the shims. The shim will be on top with the flipped u-bolts so which way does the narrow end point?
Are you SOA? Shackle Reversed? Stock? If lifted and shackles are in stock orientation the fat part of the shim goes toward the front of the truck. This effectively brings the upper knuckle bearing back and pushes the lower knuckle bearing forward. Figure three above shows it. Caster angle - Wikipedia, the free encyclopedia
One thing to note: run far and fast from aluminum shims. You want steel. Every aluminum one that I've ever seen on-line or in a store was a die casting. Those break.
Chris -
The bolts & plates got flipped but the spring & axle are still in the same relative position. The longer shackles rotated the axle forward & you lost caster. Same as the 6"ers on my '84: mondo steering wander.
Bear Frame & Axle shimmed the front axle on my '56 F100 to correct steering wander after getting the springs re-arched (Denver Spring). They're about the only ones old enough in the Denver area to know how to deal with old tech.
