Caster correction for 2" lift?
I want to upgrade to the OME 2" kit, but don't have the resources for the caster correction. I notice that the easier drop bracket correction is only available for 3" lifts and up. If I run a 285/75/16 tire and leave the casters as is, will I notice that much of a difference in handling? :confused:
I just did a 2.5" ome lift. The front raised 2.5 and the rear raised 3.0" Castor went from 2.5 and 2.6 to 0.0 and -0.1. The handling is a little twitchy now. Not bad and I took it on a long road trip 70-85 mph no probs but I will be looking to correct the castor so I feel comfortable with my daughter driving it.
Ok, lets pose the above question like this: can he use the brackets to avoid having to take off the arms, mark them up, bring the arm into a shop to have them pressed out and the new bushings pressed in. Alternatively, can he use a BFH to pound out the bushings and pound the new ones in?
Karl
for tonygray
I'm not sure what brackets you're talking about.
I've made some templates that will help anyone align the bushings to get them pressed into the arms. All he needs to do is remove the arms, take the bushings and my template to a shop and have them swapped in.
It's not that difficult of a job.
I made a template, plasma cutted steel plates from it and welded them over the stock rear arm brackets on mine in 1993, before the offset bushings were sold and the brackets were commercially available ( I guess the first ones were from Advance Adapters as I recall, I still got on my files the initial drawings of my ideas which I faxed them for their feedback, a couple of weeks later they did some samples, and were succesfully tested) and didn´t have any major complains since caster were close to oem specs after lifting the cruiser. I only noticed a little bit more tire hunting but I guess that´s normal with taller tires.
Since then I ofered both choices to our customers, but usually most of the owners go for the bushings.
I'm pretty sure that for a no banana like me it a lot easier to contemplate and bolt on the drop brackets I have than to go through all that. At the very least I can do this at home and not need the press at the machine shop.
Kalawang
Thanks for the info. Sounds like I shouldn't be lazy and take care of the correction. How can I get a hold of your template? your solution sounds much better than TLC in Van Nuys charging me 7 hours labor.:doh:
Your help is invaluable. I'll get pix up asap
7 hours of labor to install just the bushings or 7 hours of labor to install the complete lift including the bushings? I was under the impression that getting the old bushings out and pressing the new in was more like maybe a 1/2 hr to 1 hr job, especially for the pros :confused:
And, maybe this is just a Slee thing but per this --> http://www.sleeoffroad.com/products/80_suspension.htm the caster correction bushings are included with the lift as is a bushing press tool...:)
they wanted 10 hours for the whole job. 3 for the suspension and 7 for the caster correction.
$2300 for the OME kit and labor. Crazy huh?
Get the castor correction bushings, press the OME ones out, press the new ones in. EASY, SIMPLE and they are needed for good driveability. If you cannot do this yourself, search for the proper alignment of the busings and have a good local mechanic do it for you. Not a big deal and well worth the effort.
Cheers,
Sean
:cheers: Lots of good advice. I will be buying the OME 2.5" with correction bushings. Using the template, I think I'll pull off the arms and bring them to a shop to have the bushings pressed in.
here's my new bumper. paid for buy the drunken landscaper's insurance company who rammed into me. His little Nissan truck was totaled. I got away with a few dents and $5000 in shiny new body work. If he hadn't fled back to Mexico, I'd send him a bottle of Tequila.
On a side note, when removing the bolts from the arms be sure to hold the nut stationary and turn the bolt to loosen them.
That's crazy, it only takes a couple of hours.max.:rolleyes:
that's what i thought. maybe he was talking about some other method I don't know of.
