I thought i would update this thread.
I slept in my James Baroud Space Evolution model tent for 14 days straight. I will start off with the things that i found to be either annoying or needing improvement since it's a pretty short list.
1. The tent is too short. The tent needs to be about 3 to 4 inches longer to accommodate most americans. It might be fine for short european folks or Asian folks but not our market. I am 6' tall and i do fit, but barely fit. If i were 6'3" it would be too tight. They do make a larger tent, but not in this model.
2. The lift struts are too strong. It's a good and bad thing. They are strong which makes set-up a snap. Flip the 4 latches and it pops up immediately. It also is capable of handling strong wind. I slept in 30 to 40 mph winds one night in a canyon and the tent didn't budge. I did hear the zippers rattling around and that was fixed really easy by putting little pieces of duct tape on the zippers. That quieted them down and never heard them again. But, when it came time to close the tent, the struts are just too powerful and it was often difficult; especially if it's warm outside, they are even more pressurized. So they need to either get a slightly less powerful gas strut or come up with some mechanism to help you close the tent.
3. Support struts are positioned at the door entrance. I mentioned this above but i did manage to hit my head on the struts about 3 times and it didn't feel good at all. The supports that hold the roof up scissor and end up being located right in the corner of the doorway. At night if you are looking down at your feet climbing the ladder or a little drunk, you can easily pop your head on the support. So maybe they can situate the supports in another location or figure out another design.
4. Too many zippers. This is just my opinion but the door has 4 zippers then the screen door behind it has 4 zippers. Why so many zippers? Just give me one or two that zips the door open and zips it closed.....
5. Velcro at the bottom of the door. I'm still not sold on this. I would prefer to just have the zipper zip all the way around the door, not just the top and sides and then velcro the bottom. Doesn't make sense to me and honestly it's super noisy. At night before i installed my in tent restroom (large gatorade bottle), and i had to get out to pee, the velcro was loud enough to wake up the entire campsite. I would suggest them just using a zipper for the entire door like most backpacking tents.
Now for the good:
1. The LED light inside and the fan are spectacular. Very simple but are very effective. The fan is charged by a solar panel incorporated into the fan on the roof. At cruise moab i ended up taking the tent off for a couple of days and set it under a tree at my camp-spot so the solar fan couldn't recharge. After the second day, it eventually died, and that next morning i woke up and the inside of the tent was a little damp from my breath. With the fan that didn't happen. Also, the light works very well and is very bright. It comes with a charger to charge the light with a 12v cigarette style plug. But, don't be fooled, the "intake" fan blade doesn't really pull enough air through to make it feel like you have a fan blowing on you.
2. The tent is very waterproof. I slept in a torrential downpour in missouri. Woke up the next morning and everything inside the tent was dry. Not one drop of water. I was very impressed. Even where my sleeping back or pillow was touching the fabric it was still dry.
3. the tent is very air tight. With all the doors closed you can not close the tent down. It's like a balloon. You have to unzip the tent doors to close the tent because it's so well built and tight.
4. There is a very cool design feature built into the base. There is a small hole with a black rubber cover over the holes. What this is for is while you are driving down the road, those holes and the cover create a vacuum and it sucks any smell or moisture out of the tent while your driving. Really cool idea and seemed to work well.
5. The mattress is great and high quality. Like i said, i slept in this tent 14 nights in a row. On the 15th night i got a hotel room and regretted it because of other factors. The 16th night, i slept in the RTT again and slept better than in the hotel.
6. It's very aerodynamic and light as well. My old tent which was a fold out type felt like a huge brick on the roof. It was heavy and really caused the truck to lean in corners, not this one. I can barely tell it's up there. However, i could tell it was up there on a few super tippy spots in the hole in the rock trail, but other than that, it's very "wheel able". There is literally no wind noise that i could hear.
7. A lot of head room. In the tall section of the tent, i'm able to be up on my knees and my head be just short of touching the roof. It's probably the same height as the old fold out tent that i had. The front of the tent, while lower, is still very tall and you can easily sleep with your head on this side of the tent and not feel cramped or claustrophobic.
Overall i'm very impressed with the tent and the build quality. The only negative that i can think of is to make it easier to close. The struts are very strong.
