Thanks for the advice, everyone. Took my seats out of my '11 LX this morning with the help of a cheap set of trim tools from AutoZone. The shop manual illustrations showed the tabs and snaps and gave me confidence to pry at the right places.
I bought a 4' x 6' piece of indoor/outdoor carpet at Lowe's and cut to fit. Turned out OK, I think. I put some carpet tape on the bottom, but the true test will be whether or not it stays in place with the dog moving around and cargo being pulled in and out. If it doesn't work, I may buy some 1/4" rubber matting that Lowe's sells, sort of like some types of door mats, cut it to fit, and just lay it in there.
If anyone wants a scan of the shop manual showing the seat removal, PM me your email address.
You did exactly what I did (though mine is a LC). I cut it slightly wider than necessary...and they stuffed the edge under the outer edge material on the sides. If you cram the edges under the sides...all the way around to the side door area, it stays in place very well. I actually used a staple gun with long-ish staples for the back opening (where there was nothing to stuff it under) and angled the staples...alternating angles as I went across to discourage pulling it up. I's held very well for the last 5 months or so...
In fact...you even picked an identical color. Would wager it's the same stuff, as I think I did get it from Lowes.
