Carburetor??
Miami
1997 FZJ80 with with a carburetor.
Guys, I have a question about the carb.
For some reason, lately it has been starting up rough, or is hard to start. It sometimes takes 2 or 3 tries to start, and you have to give it gas due to it being a little rough, as if it were going to turn off.
This happens sometimes when turning it on. We took it to get the carb checked out, but everything is fine.
Any ideas?
Uh, I'm stumped as to how the "Carb" is OK. The FZJ doesn't have one. The 1FZ-FE motor is fuel injected.
Uh, I'm stumped as to how the "Carb" is OK. FZJ doesn't have one. The 1FZ-FE motor is fuel injected.
Howdy! IF it is actually carbed, then most of them have an adjustment for making the choke richer or leaner. I'd adjust it richer a little bit and then go from there. John
This may be totally wrong, but I *think* the South American models of the 4.5 liter have carbs, and I *think* the 70, 80 and 90 were manufactured with carbs up to 1999 for countries with no emissions laws. You may get more knowledge about carb adjustments by posting in those, or the 60 and 40 tech boards.
If you had a mechanic look at the carb and it checked out ok, it could be anything on the fuel delivery system. Once it starts and runs, does it smooth out? Meaning is it only a rough start issue? If so inkpot nailed it - sounds like a choke issue.
(It's been a decade since I tweaked anything with 4 wheels and a carb)
Tell us more about how you got a carbed 80!
yes they can have carbs. IIRC its just a 1FZ, the -FE stands for fuel injected.
Make sure the gaskets are good that connect the carb to the intake manifold. Also check all the vacuum lines.
Sorry I cant really help. I hate carburetors.
It is just a starting thing. Once it runs it levels out and is perfect. Today I had to turn it on with the gas to the floor since it wouldn't turn on.
Also, it smells like gasoline quite a bit when starting it.
So choke issue?
For those who want to check it out, here is my carbed FZJ80:
https://forum.ih8mud.com/80-series-tech/289392-south-american-fzj80.html
Wow, very interesting.
How do you pass U.S. emissions? Or maybe I shouldn't ask.....
Best of luck sorting our your issues.
Keep the Cruiser Faith,
R.
This board does not have a lot of experience with the non EFI 1FZ. From the sounds of it you have an issue with the automatic choke (assuming it is not that different than the last carb'd auto I had.) Is it possible to manually move the choke on the carburetor? If so, try to manually set it's position to see if you can clear up how it is running.
