carb?
Bozeman, MT
Who here has the pre 67 engines that run the single barrel carb? Do you have the toyota carb still or do you have an aftermarket carb. If its aftermarket what kind and what do you think of it. I'm trying to decide what I should do about mine. It has a GM carb on it right now. I'm trying to decide what to do because the GM carb doesnt work to well. Thanks
I have an Aisen 1 barrel. It is great when it warms up. Needs a hand throttle to warm up properly, which I have yet to install.
Mark (65swb45) has or had an NOS 1 BBL Aisin that I would love
to have. I have had great luck with the < '69 I BBL's but there
are many different flavors of these carbs. Mark is the guru of
the 1 BBL's, get a hold of him at www.marksoffroad.net or
perhaps he'll see this thread.
If you are learning about carbs, I think the 1 BBL Aisin is a great
place to start because they are so simple.
i have an SD-40 Aisin 1bbl large window carb runs great. I will second Idave's hand throttle, mine just broke and it need one, but i almost never need the choke
Richard, I am an incrementalist. By that I mean that I prefer to change the variables in the equation one at a time, so that I can confirm what each particular change does or doesn't do. Since you are planning on changing the manifolds, maybe that is your underlying problem.
Not that I like the GM or am saying you should keep it. I would just install the manifolds first and see what happens.
I like all the different models of the Aisan 1bbl. There are more than 6 models to choose from. I plan to try them all. ;)
Mark, could you comment more on the differences among the 6 one barrels (or do you recall a discussion where you did so)? I really only know small window vs large window. I know you picked my large window because I live at elevation, but I haven't grasped the subtilties. Also, could you post a picture of how you hooked up your hand throttle? :D :D
In addition to large window and small window I know that the later 1-BBL carbs did not
use the so-called "step up" rod, which lowers down to plug a port in the base of the
carb when the throttle is pressed. I have no idea what the step-up rod does. I also
know that the 1 BBL carbs were available with and without the fuel shutoff solenoid.
I too would love a complete description because I have a box of parts and an not
sure what they all go to.
Mark, could you comment more on the differences among the 6 one barrels.
.All in due time. There are actually more than 6 variations, I just haven't sat down and written them all out. I have all the nuances from 70-87 in my head, but mostly just rebuild and tinker with the older ones. Three different windows. With and without solenoid. Different number of access plugs and vents. yada, yada, yada.
The step up rod rgentry describes performs the function of a metering rod. The inverted taper gradually increases the orifice as it drops, concurrent with the actuation of the accelerator pump plunger.
