Carb ?
Elizabeth City, NC
I think I have a float problem but I would like some input from others. My carburetor seems to be loading up, raw fuel is dripping from both primary and secondary venturies at idle. Is this a poorly adjusted float or what?
Could be....Float could have sank...
You could also have a piece of junk on the needle/seat, preventing it from closing as it should.
What is the level in the window?
Thanx...yea junk is more than likely, I have a plastic tank that seems to have a bunch of crap in it and yes it has been cleaned out at least twice. I just cleaned out the carb and installed a new fuel filter with a paper filter, hopefully that will help. I will open the carb and chek the float and clean if necessary.
Since your sig line indicates that both your carbs are pre-75, you should be able to remove the access plug directly above the needle and seat assembly to see if there is debris holding the needle away from the seat.
If you find arc shaped brownish debris in the fuel bowl, consider the possibility of shellac in your fuel lines at some point past the fuel filter may be a culprit as well.
Best
Mark A.
Best
Mark A.
What is Shellac? I have both Brown bits and Black Bits. I opened the carb up for the 3rd time and found more crap in the fuel bowl and in the seat.
