carb tuning (2f)
Calgary
after a fresh carb rebuild, what's the first action you should take towards getting it tuned? just rebuilt my '75 carb, installed it on my '73 F, need to get it purring again.
it runs (badly) for about 10 seconds and then sputters and dies.
what's first? TIA :cheers:
ninja edit: 500 posts :grinpimp:
idealy to tune it you want it barely running but running.and that is done by backing out the idle adjustment all the way off.and getting it too idle at like 350rpm with the mixture screw,then you time it.and on and on.it sounds to me like its not gettin fuel.so start there
i got it running, i think i have other problems though...
set the float level again (properly this time) and it ran with the choke, got it warmed up nicely and then screwed around until it ran fairly nicely, a little lump in the idle though. gave up for the night but hopefully tomorrow i'll get it all smoothed out.
now for the bigger problem: the accelerator pump isn't pumping... it won't squirt anymore. looks like i'm gonna have to take the horn off again and dig around in there... nobody happens to have a pic of what it SHOULD look like when its put together properly? i just don't see how i could have screwed that part up.
My first instinct when I hear the words 'lump in the idle' is that you don't have the rpms low enough to avoid engaging the primary circuit. At idle, you should not see gas flowing out of the primary into the carb. Chances are, you do, and that is the source of your 'lump'. The trick becomes determining what it will take to stop that.
THis has been covered many times in this forum, often with imput from Jim C. and myself. Magoo's point is really the best place to start: assume NOTHING and be ready to experiment with ANYTHING!
thanks again for the help guys, i'll keep updating this thread with more questions as i go along :) i'm not too worried about getting it tuned up nicely, i'm sure any sucker can do it given enough time: what i am worried about is the accelerator pump not functioning.
what a PITA. i probably would have been better off sending it away, but hey, i haven't ever had anybody else work on my truck and i guess that's an accomplishment (it shows though ;p)
