jjhancock said:With respect to dipping / rebuilding the carb, I'm concerned with even getting the truck to run afterwards considering how finely-tuned this thing (I'm guessing) must need to be in order to function?
It's not rocket science. The FSM shows a number of settings, like the float level, secondary mechanical opening, throttle positioner opening, but these settings should not change from the way it left the factory. The idle mix and idle speed are adjusted on the outside. It will run well within a pretty broad range of these settings. The trick part of rebuilding them is making sure that they go back together the same way they came apart and making sure that all the tiny holes are clear. You have to pay attention.
