Yep, Q-Jet. The numbers are hard for me to see but I think I see 1, 2, 3, and 4.
1 is the choke as pin_head said. It does appear to be missing the metal tubes that allow intake manifold heat to be transfered to the bi-metal coil inside that can. Without the tubes, the coke won;t work very well or not at all.
2 is where one of the metal tubes for the choke connects. the other end (its really a loop of metal tubing) connects to the rear top of the carb in order to draw in clean air via the air filter.
3 is an EGR and it does not appear to be connected corectly. From teh picture it appears to be connected directly to the carb. Generally, the EGR is connected to the carb but via a vacuum switch that is controlled by the engine coolant temperature. At low temps (warm-up) the switch is closed to prevent the EGR system from functioning. If the EGR is allowed to function (direct exhaust gasses into the intake manifold for combustion) during warm up then the engine will be running very lean during these times and it could stumble, hesitate, or stall.
4 is not clear enough in the picture for me to tell. I would guess that it appears to be a vacuum switch like what is used to control the EGR but again its real hard to tell from the picture what it is as well as where the vacuum line is attached. That can is the seconday pulloff mentioned my pin_head. Using vacuum, of actually lack of it, it controls how fast the secondaries are allowed to open. Under high vacuum, it will nto let the secondaries open. In low vacuum conditions it allows the secondaries to open as well as the speed at which they can open.
To me , this Q-Jet appears to be post-74 because of the top cover shape and would likely contain an APT (Adjustable Part Throttle) device. This era of Q-Jet are known for a very lean idle (because of smog requirements) and can be somewhat more difficult to tune to get a good crisp and strong off the line accelleration without some stumbling. At least thats my experience.
