Carb Question
Utah
My butterfly valve in my secondary barrel was siezed. I tried all of the tricks I knew to free it but, but with no luck. I decided I needed to remove the butterfly. I broke the screws taking them off, but I knew this would happen. I was able to extract the broken screws without any problems. The question now is why would I have to use brass? I found some stainless that fit perfect, and I don't see what if any problems using stainless could cause. Please let me know if the stainless will cause any problems.
Thanks
Scott
I believe they are brass because they need to be ???? (I forget the term). Basically the end is puched and deformed a little to prevent it from loosening and falling into the intake.
I think they use brass because it is easier to peen or stake, whatever they call what they do to the screws to keep them from coming out. Maybe just red loctite? And good luck getting the shaft unstuck.
Ed
WHOOPS......too slow
Yea, I was able to use a hammer and I tapped the shaft out. I used some Toyota lube to clean out the housing. Everything work great now, I just need to put it back together. I was thinking red locktite as well, I was just not sure if the fuel would have any affect on the locktite.
Thanks
Scott
Give a message to 65swb45 (Mark). He'll probably havethe screws too.
In a perfect world, where your cruiser is a daily driver and not a weekend toy or part time recreational vehicle, it wouldn't make as much of a difference.
BUT, in the real world, where the vehicle sits for a while between uses, and moisture accumulates, more so because we're talking about the secondaries:rolleyes: the brass is some mighty cheap insurance against the screws rusting into the shaft.
The fact that they come pre-dimpled to make staking them in place easier is also a good thing.
They should still be good in stock at the dealer; just need to be patient for a few days to get them.
Do it right or do it twice.
Best
Mark A.
When i tore down my very first carb that far and went to find new ones I asked the same question at a place that just did carb work and they said it had something to do with heat. That being said they could of been feeding me a line, but it worked for me and i went and found some brass ones, and this was about 15 years ago also.
No problems w/ stainless screws. It is soft, weak and corrosion resistant, similar to brass. Nick the end w/ a sharp chisel to keep em from falling out, and use a little hi-temp loctite to keep them tight.
Well, I probably should have used brass, but the friend that I was doing it for did not want to wait. So, what I did was get the stainless screws, used the hi temp locktite, and staked the end with a punch. I hope this will be sufficient. Figuring that the entire carb base is made of a ferrious material and so is the shaft that the butterflies attach to, I don't believe this will cause any issues. I do believe that it could be to prevent the screws from rusting, but being stainless I hope this will keep the rust problem from happening. If I have a chance to take the carb apart later I will post and let everyone know what the results were.
Thanks
Scott
