Carb Question - 79 Pig
Discussion in '40- & 55-Series Tech' started by LRIwater, Mar 2, 2007.
  1. LRIwater
    LRIwater SILVER Star
    266
    9
    Oct 16, 2003
    San Diego, CA
    I have a '79 desmogged Pig with what seems to be a stuck float (gas flooding out of bowl vents and completely full sight glass). What is my best option here? I tried percussive maintenance (tapped it with a rubber mallet) with no luck. Should I get a pre-smog carb to reduce all of the vacuum tubes (would that even fit?), rebuild the current carb, get a new float, or just try to mess w/ the old float first? I have rebuilt carbs before, but none with so many frickin' doodads coming off of it!
    Thanks in advance,
    Chuck
  2. jjhancock
    jjhancock
    336
    Nov 2, 2004
    Boulder, CO
    Take it off and send it to Jim C on this board.
  3. 65swb45
    65swb45 Supporting Vendor
    21,747
    6,459
    Apr 14, 2004
    so cal, going 45
    Answer depends on whether you just want to fix your problem, or if you want a good carb. I personally don't like the 79-80 model. It can be improved, but only to a point.
    Older, newer, and non-US are all better options IMO.
    All still available as rebuilts:
    V
