Carb problem
DEN
I just developed a stalling issue. 40 was running fine at highway speeds, but when I came to a stop on the trail or street it would stall. After searching many times I believe idle solenoid may be culprit. I have a 2f with aisan carb. 76 FJ40. Unless I pull the choke out and idle very high the engine will stall. How can I tell if it is not getting enough fuel or flooding somehow?
Is the solenoid easy to remove to replace o-ring if that is problem? Where is the screen on the carb I have read about and how can I access it? I had a very dirty gas tank a while back and maybe it is full of crap.
Thanks
the screen on the carb is a little glass circle, you should see a visible gas line if it is clean, on my 1F it is about half way up the carb facing towards the radiator. I have the same problems you do but have checked my idle solenoid by taking it out and connecting 12 volts to it. mine was only 2 screws and fairly easy to take out. try replacing your fuel filter as well.
bandy has the screen and the sight glass confused. The sight glass shows the level of fuel in the float bowl. If the level in the sight glass is much below half-way, your float could be set too low and this could cause your stalling problems.
I do agree that you should change your in-line fuel filter or at least check that you're getting full flow through it. The sceen you're referring to is right where the fuel delivery line attaches to the carb. It's shaped like a little thimble.
Pete
You can check if the solenoid actually energizes by turning the key to the on position and disconnecting and connecting connector to soleniod. Should be able to hear some clicking when you do this. You can check if the O ring is still intact by removing it but sometime when doing this check it falls apart on you. Another thing you can check is the EGR valve.....if stay stuck in the open position it will have a hard time idling but will run fine on the highway until you let off accelerator. If this is indeed happening sometimes tapping on a little my clear problem. You could als remove and try cleaning it. Check for a vaccum leak.....check all hoses including the one that goes to the brake booster. Also the if the intake/exhaust leaks badly you get the same symptoms. If everything else checks good the Carb may be clogged in the idle circuit.
Good Luck.
I believe I figured it out. I followed the wire from the idle solenoid to under the dash. I then glanced up at the fuse panel and noticed the 2nd one from the bottom was blown. That just happens to be the "engine" fuse. I replaced it and now all is well. Thanks
