carb jetting
Prince George, BC
I am currently trying to rebuild a 1974 fj40 carb. I got a keyster carb kit on e-bay and started tearing the carb apart. The kit I received has none of the same sized jets that are in my carb, so I was wondering if I should use them or just keep the old ones in.
My jets have these numbers on them: primary main jet 20
secondary main jet 18
shorter slow jet 55
longer slow jet 80
there are also spare jets on my carb for the primary main 114 and powerjet 55
The kit contains: 1 shorter slow jet 60
and a 180, 118, 60 and 50
Are the numbers on the jet in mm? What happens when a larger or smaller jet is put in?
Above 6000 feet you are supposed to change to the high altitude jets(on the primary only). These are stored in the Bowl caps on the front of the carb. When you remove it, the extra jet is screwed into it on the reverse side. You can change the jet through that access if you have a split-blade screwdriver.
The secondary jet doesn't change.
GL
Ed
