So I'm still fighting the emissions gods...
I've done a home rebuild on my carb (OEM 71 vintage), and it has been an amazing learning experience. With that said, and after mutiple re-dos I still can't pass emmissions.
I've found a strange abnormality with my carb. When rebuilding I replaced the jets with the ones from the rebuild kit. Put it all back together and it runs like crap. I come to find that the previous owner had redrilled his jets to some unspecified bigger size. After experimenting I can get it to run perfectly with the redrilled (old) 1.12 and the new 2.0, but as soon as I put the new 1.12 in, it runs like crap again. So this is all dependant on the primary jet being bored out bigger then spec. I almost passed the emissions test with the old 1.12 / new 2.0 setup, but was still high on the CO at speed.
Definition of running like crap: will run great with the choke partially open, will idle like a champ with the choke closed. As soon as you close the choke and try and gas it, it sputters and tries to die. If you pump the pedal you can kind of get it to rev, but it's not drivable without the choke.
Thanks for any ideas you might have. Fire away with any questions.
- Tim
- Tim
