OK. I am going a bit vcrazy with this carb on my 1980 FJ40. First it would not idle. Now it idles but will die after you press the gas and then let it go back to an idle position. I let it sit there for minutes, no choke and it idled fine. I hit the gas, it revs and then dies.
I did not notice that my linkage on the carb base seems a bit lose. Not sure if this has been an issue but adjustments have been difficult i.e. not standard each time I have taken off the carb due to linkage slop on the carb (linkage from the pedal is tight).
The 40 runs so much better now MINUS the idle issue. Solenoid is working-I verified by both hearing the click AND taking it out and testing.
Any thoughts?
Any thoughts?
