Carb Insulator Needed
Maricopa, Arizona
Well after ripping off the old one and tearing the gasket like material on both sides I need one thats not messed up :bang:
I thought for sure it was just a gasket that could be replaced...:whoops:
Just to clarify it's the piece the carb sits on that sits on the intake manifold, that the PCV valve hose connects to.
2 Barrel style.
does it look like one of these? I've got them with no vacumn ports, 1 port and 2 ports Skip the manifolds, it's the pic I had handy.
others, I've heard use a belt or disc sander to make the surfaces flat again. might work, also DO NOT USE any form a gasket type material, gas and those materials don't play well together.
You might try marksoffroad.com :: this domain is for sale. I saw under his "special" deals section that he makes an aluminum carb insulator. the picture doesn't look like what you have but he may have something he is not showing on his website.
Sorry, the carb insulator on marksoffroad appears to be for the 1BBL. Specter has them used for '69 - '74 for ~$50 (which is what yours appears to be).
after doing some more digging, I did find one like that, actually 2 of them.
I'll get a better look in the AM and post a pic or two
