Carb fuel inlet?
Kansastitty
This may sound dumb, but i run a '74 carb in a '66 cruiser so it does not have the fuel circulation that the '74 carb was designed for. Consequently one of the inlets is plugged. In the picture, which is the actual inlet, the one on top with the banjo fitting, or the one on the engine side? Currently, mine is plugged on top and fuel enters through the side. Seems to run fine.
Thanks,
Ed
You've answered your own question with "seems to run fine". If you MUST know, take it apart and look at the passage routing, if any.
Well, they both go to the same place and it does work either way. But there is supposed to be a little brass screen in there and if that is installed it looks like it would only filter from the top inlet. I just wondered how Mr. Toyoda designed it.
Thanks,
ed
I have a 75, I think it's a similar carburetor, but I'm not sure. I don't think it makes a difference which one is the inlet since they both connect to the same place inside, but it DOES make a difference which fitting is used. When I got my car, the lines were switched, with the inlet going through the banjo fitting. I found out that the small opening on the banjo fitting will not flow enough fuel at higher speeds, so you will have fuel starvation issues if it's not correct. If you're gonna plug one, plug the banjo fitting
Thanks, that's kinda what I thought. The orofice looked really small. I run without the screen as I have two filters and one right before the carb.
Ed
The one on top is the return line. The bolt that screws down thru the banjo has a very small brass restrictor in it, which would not serve well for fuel delivery.
Besides, if you think about it, since the gas flowing thru the restrictor would be INSIDE the open-top filter screen, it would make the screen pretty pointless.;p
Too late on a Saturday night.:sleep:
Mark, I can't seem to find anything the right size to plug the return. It is not pipe thread and does not seem to match any bolt threads. Special carb-only part?
Ed
Ed
If you haven't figured this out by the time I get back from TX, give me a ring and I'll test a few things out at the shop.;)
Mark A.
Mark, it is 11mm x 1.50 thread. I have not been able to find anything close.
Thanks, hope you have a great trip!
Ed
Ed,
There is an 11x1.5 plug in that hole in all 1970-1972 carbs. Dig in someone's Cruiser parts pile and you'll find it.
PM if you need one and i'll get one in the mail. I think I owe ya still.
