Carb Experts
Maricopa, AZ
Before I processed I wanted to get some advice from the experts.
I've done research and realize that the insulator is suppost to have a factory baked on gasket. After I rebuilt the carb. (six months ago) I had some noticeable backfacing mostly with it was cold. But I remember that my insulator didn't have this factory gasket and there was evidence off scraping. Since I have everything off for my head work I figure it's time to fix that problem.
Dose this 99cent fix job meet your expert approval. Figured it was worth a shot, I got the material from michaels. Its been holding up for several months when I used it for my heater unit. I got the idea from that ebay add(rebuild your heater unit), funny how 99cents can go a long way. LOL
here's a link to the picture since I've past my limit.
http://i12.photobucket.com/albums/a202/m1n166/IMG_9181.jpg
thanks in advance, for the info.....
If you are talking about replacing the insulator gasket, a piece of cardboard from a cereal box would probably work as well.
I doubt that the insulator seal has anything to do with your "backfiring" (out the tail pipe or carb?). A vacuum leak below the throttle plate would make it idle rough, but have a decreasing effect at higher speeds.
