Carb dead spot
Alabama
My 40 is in the shop right now, but when I had it, on a cold start, the carb had a dead spot. When I press the gas pedal, there is a delay until the engine revs. This only continues until the engine is warm enough. What is the problem?
I use the choke on cold start until the temp comes up at least half way to "normal" operating temps. Maybe not an issue in 'Bama?
Ed
bandy rooster said:
do you have an electronic choke?
No it's a manual on the original 2f. The guy restoring the car used to be a mechanic and says the the carb is bad, and will eventually have to be replaced. However, once the car is warm, it runs fine.
I would look at the carb accelerator pump. I'm not 100% sure about the 2F carb but my F carb had a leather "piston" that would need to be replaced every so often. It's an easy fix and can be done with the carb on the rig. Might be worth trying before you replace the whole carb.
It COULD be as simple as a choke-related problem. Then again, the carb could be running less than optimally vacuum-wise, and the vacuum improves as the engine warms up, thus mitigating the problem.
You should get some cold spec vacuum readings with and without choke and compare them to warm spec vacuum readings and report back. FWIW, I run the choke at various points during the day during startup, cold or warm. A well calibrated choke is a wonderful thing.
Also, remember, we ARE talking about a 79 carb here.:eek:
It does not bother me. If i leave it alone, will the problem get worst.
