There's two 'relays' !
One - behind passanger side kick panel; senses copnditions at sensor,
controls another relay (that powers fan), has timing circuits etc.
All this stuff is in a black box, second up from bottom of stack.
(bottom one has , umm had, that damn little beeping thing...key & seat belt alarm)
The 'another relay' is behind drivers kick panel, little 'can' relay
actually controls (on - off) volts for fan motor. activated by 'black box' noted above.
How do you test these relays?
My fan is not working.
I took the thermo sensor (resistor) wire apart, cleaned it up, and also tried grounding it to the frame. Still not working.
Took the fan out, dissasembled the blower, and checked it. Runs normal with 12 volt power supply. The housing was clean- no debris.
The fan ran good with direct 12V power once I reinstalled it, but still not working after driving (and it is hot enough here for it to work).
I checked the voltage at the 2-wire green plug to the fan after driving- 0 volts. I assume one of the relays is not working, but don't know where they are or how to test them.
Anyone have pics of their location? My 60 has been noticeably more difficult to start since the fan quit working recently.
Thanks.
