Car cranks but doesn’t start
California
So after changing 3 seals oil pump, crankshaft , and distributor o-ring I think I might have messed up something along the way, most likely the timing or something. Can you guys help me adjust whatever needs to be adjusted. Thank you
Quick question: “Rotate the crankshaft until the timing mark is on "0" on the timing cover”. How can you tell where is 0 on the timing cover? All I see is 15, 10, and 30?
That red cable attached to the battery post is a disaster waiting to happen. Get that fixed ASAP.
As posted in your other thread the timing marks are 15, 10, 3 and 0
Thanks for pointing that out I was reading it as 30
Looking closer at the photo it looks like the battery is just sitting there unsecured. Do you even have a battery box? In that condition you could easily have some major issues including burning down your truck. It is possible that you no start issue could be caused by failed fusible links stressed by the movement of the battery.
I took the battery box out to make space because I was replacing oil pump seal and crankshaft seal and also distributor o ring which screwed me over lol
And it turns out I still have a leak from this spot after replacing all those seals
I see alot of shortcuts on this picture. People rushing to just get things back together to start it.
That's either rear main seal ( most likely ) or the valve cover gasket on the back.
Rear main means pull the transmission out.
You should get a fsm so you can learn. Did you follow a thread on here for guidance?
As far as the no start.
When you removed the distributor, did you make sure it was reinstalled exactly?
Wires in correct location?
Rotor pointer location?
Coil wire?
Do you have spark?
Coil wire?
Do you have spark?
No. Unfortunately, I didn't reinstall it exactly, but everything else you mentioned I did accordingly for some reason it still won't start it could be that I am off by a tooth or so.
Rear leak might be this:
@Masud when i replaced the distributor I also did a front crank seal and oil pump seal etc. Forgot i moved the crank in the process and tried to set the distributor at 1 on the exhaust stroke of Top Dead center (a.k.a. zero) of course it didn't start. was simple to rotate and get it set right the second time.
I tried like 3 times for some reason every time I would get the same response, crank crank crank but wouldn't start. ill figure it out sooner or latter.
Since you have cranked the engine, you MUST start from scratch.
1) set the engine on the compression stroke on cylinder 1 to top dead center. Do this by removing the spark plug in #1 and stick something in the hole to feel compression. A compression tester is best, but a paper towel can be good enough if compression is good enough to blow it out if the hole. Once you know it's on the way up, then stop at "0" TDC.
2) Remove the distributor cap and see where the rotor is pointing. It SHOULD be pointing at #1 on the cap. If not, pull the distributor, rotate the rotor and reinstall so that when fully seated, it is pointing at #1.
3) replace the cap, check all connections, and attempt a start.
