Can't Shift From Park - HDJ81
Philippines
Hi,
My LC has been troublefree for the last couple of months. However today, after driving for 2 hours straight and while temporarily parked, I pressed the brake pedal and the big button on the transmission knob, but it won't shift. This is the 1st time this happened. So I pressed the red emergency shift button and I can shift. But everytime I shift to Park and then try to shift again by stepping on the brake pedal , it wont. Good thing the red button is there so I was able to go home safely.
What do I need to check? What could have caused such behavior? Hope it can be fixed (and is a simple fix) as it is quite inconvenient to always push the red shift button.
I tried the Search function already.
Something is wrong the brake light circuit.
Check the bulbs, the switch on the pedal and the fuse.
I bet you have a bulb out.
