Can't get code 71 to clear
Alpine, UT
Well, on my stock 94 I've been battling this freaking CEL code for weeks now.
Here's the deal:
I replaced the modulator, the VSV and all the vacuum tubes associated with them a couple of months ago. I also cleaned the sensor in the base of the EGR.
When the CEL came back on, I removed and cleaned the throttle body and then cleaned the little pipe in the intake. I thought that would solve the problem as the the pipe was jammed. Well, about 4 days later, that friggin light came on again! So, as I was inspecting it, I found a vacuum hose had slipped off the VSV during reassembly. So, with glee, thinking this was the problem, I slipped the hose back on.
After resetting the codes, the CEL came on immediately after two drive cycles!:mad:
I've done two tests on the EGR valve, and both times it checked out as functioning.
So here's the question: I have NOT cleaned the EGR or the egr port in the plenum. Do you have to remove the EGR to clean the port? If so, would it be worth it to replace the EGR in any case just to be sure?
Is there anything else it could be? I'm going nuts!
BTW, the CEL has been on for a long time. Also, the code ALWAYS is 71.
Thanks boyz.:cheers:
Every time. In fact, when I cleaned the TB, I reset it and it didn't come on for almost a week. It's after that that I found the vacuum lines had become disconnected. After I reconnected the VSV and reset the code, the light came on in one day.
monte,
Check your EGR temp. sensor with an ohmeter. FSM will give you the parameters. After going through all the same steps as you, that is what finally cured my code 71.
How I test cars w/ egr codes is to hook up a vacuum gun to the egr valve while it is running and apply at least 15 in vacuum to open the egr valve. It should cause enough of a vacuum leak inside the intake to make it stumble really bad or kill the motor. If theres little or no change then the egr ports are stopped up. If it's not stopped up the your problem should be on the outside of the egr system.
Did you ream out the vacuum line ports?
On the VSV itself or others? I did ream out the little pipe that runs through the intake from the VSV to the EGR.
I did all of them except the VSV, EGR, TB, etc. Hope that helpsl
When I did all this, I also replaced all the vacuum lines with new Yota lines. The old ones were just barely hanging on in some cases. I replaced the EGR valve at the same time and a new VSV.
In my case, I am almost sure it was the port that runs from the EGR valve to the top of the intake, as it was plugged solid.
I talked with Robbie about all this at the time, and, IIRC, he said it was usually one of three things that threw the "71", EGR valve, VSV, or temp sensor. I proactively replaced two of the three and saw the plugged EGR port and figured I was good. Plus, it's easy to replace the temp sensor after all this other is done !! Robbie said the plugged EGR port was a new one on him, but, admittedly, that was about four years ago.
Best of luck
R.
this just happened to mine. when you have the throttle body removed, there is a hole about 1 cm in diameter. that is the port from the egr valve. that hole dead ends at the throttle body, but its has a 90 degree down turn about 1 cm into the phlemum(sp) mine was clogged and throwing 71. gunked all with carbon. 1000 miles later no more cel or pinging with a load.
mitch
817-714-0599
Dude, you guys rule. This may be the ticket, because mine pings a lot too.:idea:
when you tested the egr valve did you get the engine stumbling? if so, i don't see how you can pass the factory vacuum test for the egr if the port in the plenum between the egr valve and the throttle body intake is blocked. if it's blocked then inducing vacuum to the egr valve should not bother the motor.
anyway before you go there, a couple of suggestions that are easier...
test the temp sensor.
on your 94 do you have the long additional set of metal vacuum lines between the throttle body ports and the modulator? if so, are you sure those are clear. I had to bypass a couple with longer vacuum hoses because there was crud in there i could not get out.
also, are you 110% sure you have the hoses hooked up correctly? especially the finicky ones down under the plenum?
Thanks for the response. The EGR test did indeed cause the engine to stumble. I have only cleaned, not tested, the temp sensor. I do not have metal hoses you described. I'm 99%, not 110% sure that the hoses are hooked up right as I replaced them one by one. I will check that temp sensor.
Thanks
