Can't brake at start up?
So, it's winter time and now when it gets cold (pretty much every day) I fire up my truck and it starts up fine. HOWEVER, I have no brakes. I have to pump them a few times and even then it may take a minute or two for them to kick in...... and then they are fine. It seems like the truck just needs to warm up. This does not seem right to me and I did not have this issue last year. I might get remote start to help resolve the issue if I can figure it out, but I am trying to figure this out before I drag it into a shop.
seems like something in the vacuum lines isn't working right
maybe the EGR is leaking vacuum while the motor is cold?
if you have a vacuum guage, you could test my theory by watching the guage while the car is warming up, to see if it fails to pull vac early on.
certainly a good first step is to look around under the hood and reconnect any loose vac lines and/or check for cracked/broken/dried out vac lines.
