Cannot remove rear hubs??
Johnstown, CO
I wanted to take a look at my rear brakes, but cannot get either hub off. I tried to spin the little spinner, but I think it actually pushed the brakes against the hub further tightening it. I put bolts in the two holes and tightened them down, but they only came off a bit. I was afraid of breaking off the bolts in the holes, so instead I stripped them out. I think the brake pads were still hitting against the hub. I sprayed penetrating oil on the hubs, so I willl let that work for awhile. Any ideas? I think it all stems from the little spinner, me turning it the wrong way....What way is it supposed to move?
First, make sure the parking brake is off :)
The spinner (parking brake adjuster) spins down to back the parking brake pads (shoes?) off, up to tighten them.
Even then, I've found the hub can be difficult to get off sometimes. If you've done the above and it still seems stuck, my approach has been to work the bolts in a 1/2 to full turn at a time each side, spin the rotor/hub till it moves freely, and repeat.
HTH
Howdy! Try turning the brake adjuster the other way, a lot. It is a very slow mover. Go twice as far the other way as you did the first time. the pads are probably extended beyond the lip on the inside of the drum. John
Thanks for the replies....i tried it again making sure that the adjuster was moving the right way, but still could not get it. I didn't realize that I had the piece that kept the adjuster from moving. I finally muscled it off and then was able to use two screwdrivers and easily get off the other side. Guess I am off to the store tomorrow for new brake pads....these things are THIN. My parking brake will have to wait awhile, as I need pads first. Thanks for the replies, it helped to know I was going the wrong way to begin with.
