This pic is where the exhaust pipe flange mounts to the manifold on my 02/80 FJ40 (stock manifold = no headers). The donut gasket goes in between and is recessed into the manifold lip. The problem is the ex pipe flange does not competely cover the hole in the manifold - you can see the edge of the new donut gasket through the crack.
I can't imagine this is as it is supposed to be. But the ex pipe flange I removed lines up with the studs on the manifold and has the converter for two pipes which mounts correctly to my exhaust system (via another gasket).
Thoughts would be welcome. I don't want to put this back on until I can figure this out.
Regards,
AndrewT
Regards,
AndrewT
