Can Someone Tell Me What This Is?
Encinitas, CA
Just completed front crank seal and oil pump o ring. My goal is to chase leaks from front to back ;) seems like i need to address power steering pump leak now but also on the front of the engine there is a large hex bolt that seems to be leaking as well? What is this for and what do you guys do to stop it from leaking?
That’s the galley for the oil pick up tube. Clean it really well and monitor not a common leak area. It uses a crush washer and should never leak unless it’s been messed with. Leaks from above leak down onto that area and it is easily mistaken for a leaking area. Take a can of brake clean to it.
Gotcha, so if its been messed with, would pulling it and replacing the crush washer might be a food idea. That is if i clean it all up and find it is indeed coming from it vs somewhere above?
Ditto: wash that area off, watch it closely to see where the leak starts from. More likely it's coming from above, even the oil pump cover
if the O-ring you just replaced got pinched/out of position.
Is it Engine oil, ATF/PS fluid, Coolant??
