I'm working on doing a vavle adjustment and head bolt retorque, and I came across some contradictory advice when I searched "retorquing head bolts". Under the post titled" Head bolt retorque - warm or cold" it was suggested that this should be done on a warm engine before adjusting the valves. Under "Valve adjustment and head bolt retorque " the opposite was suggested. Anyone else want to weigh in on this? Also, should the rocker arm bolt adj. be done warm or cold.
Another problem I have run into is how to get to the #1 bolt in the tightening order listed in the Haynes manual (it's the one in the center of the head that is slightly offset from the other 6 on the passenger side). It sits directly under the rocker arm rod, and I can't even get my #19 socket on it let alone the torque wrench. I can't imagine I need to take off the whole rocker assembly to do this. It there a special kind of low profile torque wrench, or am I just over-looking some obvious (or not so obvious) trick. Thanks for the help!
