can I do 65PMH ish
RFB
97 FZJ80 LIFTED SC DUAL BATTERIES,37s
Nahant Ma.
Website
www.youtube.com
with front DS removed and CDL in?? I need to take driveshaft to shop that is somehow amazed that I think THIER work has effected my vehicle. truck was fine no issues took DC driveshaft they "repaired" it now truck vibrates like a bastard up to 35 MPH so long story short is it OK to drive truck 40 miles in just rear wheel? I dont want any more unseen issues.
Yes
  • Like
Reactions: RFB
Plus can anyone ship a new DC Driveshaft out to me quik?? I should have never trusted a DRIVESHAFT specialty Shop apparently what was I thinking. and if so exactly what measurments are needed<
Contact @Dissent he has one he is trying to sell.
Yes. Not a problem at all.
Did you make sure it is assembled in the correct phasing?
I did I went IN and then OUT same thing. I took it out entirely and it appears its the REAR DS Is it possible I knocked it out of alignment installing new U joints?? Im getting it balanced tomorrow.
Check the phasing before you do anything drastic. Odds are it was installed incorrectly. Note the front and rear shafts have different phasing.
J you have yours same as shown In FSM? I keep hearing the manual was wrong.
I do, yes. Check out my older thread on this topic. Rear driveshaft has a serious case of the GRRRRs. What to check next?
My rear driveshaft came incorrectly phased from the previous owner.
No issues until I installed taller lift springs. Then it started getting really bad vibrations. I didn't suspect the phasing because 1) I hadn't messed with it before) 2) it was phased just like the front driveshaft and 3) I never noticed it before until I went with taller springs.
That's when I referred to the FSM and realized my rear driveshaft was setup incorrectly this whole time. Oriented it just like the FSM showed and the vibrations went away.
Awesome, thanks Brother. I have put a lot of time into this truck and she needs to make it out your way and back this is the last thing I need.
The rear prop shaft is pictured in phase. Zerk fittings may be offset but CC is in phase top and bottom
Yep. Drive it like any other rwd vehicle.
I've daily driven mine for months at a time with the front shaft out, CDL locked, and also driven 1000s of km with rear shaft out and CDL locked due to blown rear diff pinion bearing
  • Like
Reactions: RFB
