Can I delete the Cats???
NE Georgia
So
Now I have an 80..... LX 450 really but first thing i removed the running boards
now I have two problems
I need to know where to get the end pieces for the front flairs
and more importantly can I delete the catalytic converters without screwing up the functioning of the computer and or the engines operation???
I have bad memories of pulling smog equipment off of a 60 and having serious performance issues.
Have you given any consideration to the O2 sensors and their data feed back to the engine controls. No sensors would probably 'flag' your computer to drive illumination of the check engine light (associated code for the faulty cats). It is my understanding that the computer will adjust the engine parameters, so your hunch appears merited so you will want to review the manuals to see if it can be done in a manner that will minimize adverse performance changes. I recently replaced the O2 sensors on my wife's '95 and the mileage jumped an average of 2 mpg for the truck, so performance can be affected.
Also, will this truck require emission testing where you live in Georgia? If so, you would probably fail the emissions test, because they look to ensure that the cats are installed and an illuminated check engine light is grounds for failure (no test) where I live.
Good luck
I have a '94 with missing cats:rolleyes:...it runs fine. Usually, if your O2 sensor is in front of the cats, you can remove them without much trouble. However, if you have a sensor behind your cats (I think yours does) you'll need to get an O2 simulator.
Put on a new style single cat. Low profile, low cost. There are plenty of threads on here about them, just search for "cat" or "converter". We can't keep ruining the environment fellas, our kids have to breathe this air too.
Call Cdan for the front mud flaps (end pieces for the front flares per your description) if you want them.
Thanks Ya'll
Yep thats what I found out today
The single low profile freer flowing cat is probably how i will go
and I ordered the matching end caps for the flare at a local lexus dealer
I have heard about cruiserdan but don't know how to contact him.
Thanks for the feed back next dilema is stereo system.
I will post elsewhere about the bad news i found there.
Thanks again
G
thanks,
G
My '92 3Fe had the cats removed before I bought it. O2 sensor is still intact. Other than strong exhaust smell, I have no check engine lite.
I would assume I have a bit more HP too, but nothing to compare it too.
Im sure I wont pass emissions come next Aug when I need to pass the mirror/sniffer test, so Im delaying the cost of the new exhaust system until then.
