camshaft question
Netherlands
The first "cam" of our camshaft was bad. We found a new aftermarket camshaft, 13511-60060, which should be the superseeded version of the camshaft in the F135. (All camshafts for F and 2F are equal?)
Now the old shaft has holes in the bearing between the 2nd and 3rd cilinder. The new one has holes in the bearing between the 4th and 5th.
Are these holes for the rocker shaft feed line? Is this a production fault or did this change? Can I use this camshaft?
